3 of the Same, 1 Different
Old Mar 24, 2009 | 02:39 PM
Xander2002's Avatar
Xander2002 is on a distinguished road
Default 3 of the Same, 1 Different
When I bought my 2002 blazer it came with 4 235/70/15 (28x9.3/15) firestone tires, unfortunately about a month and a half ago my back right tire went flat so I out the spare on which is a 235/75/5 (18.9x9.3/5). ive now been driving around for about a month and half to 2 months. im pretty strapped for cash right now so thats my reason for not getting a new tire yet. I just want to no if driving around with a different size tire will cause any damage to any parts?
Old Mar 24, 2009 | 03:20 PM
oisinirish's Avatar
Everything I've heard is that two different sized tires will cause extra wear on your rear differential.
Old Mar 24, 2009 | 07:17 PM
Put the larger tire on the front and do NOT use 4wd. But get a properly sized tire quickly. Some tire shops sell used tires that still have good tread on them. Check around, you may be able to get a decent tire to use for cheap.
Old Mar 24, 2009 | 08:13 PM
WolfPack's Avatar
ebay has good deals on some used tires
Old Mar 24, 2009 | 08:47 PM
mdehoogh's Avatar
Avoid burnouts with different sized tires, or else you'll end up like this dude
But as others have said, make sure you have the same sized wheel/tire on both ends of the same axle, 70's on the rear and 75's on the front and not 70's on right side and 75's on left side
Old Mar 24, 2009 | 10:11 PM
TripleBlackBlazer's Avatar
truth
Old Mar 25, 2009 | 10:20 AM
Xander2002's Avatar
thanks for all the input guys, it really helped
Old Mar 25, 2009 | 01:37 PM
oisinirish's Avatar
Just a question on this subject. Will different size tires on the front affect braking and handling?
Old Mar 25, 2009 | 01:40 PM
It will affect handling, but not really affect braking. It is just a lot safer for the driveline components so long as 4wd is not used.
coolcat0285
Nov 14, 2012 07:35 PM
pdl122000
Sep 5, 2011 04:28 PM
mikepro
Aug 15, 2011 07:03 PM
AmberRose
Aug 30, 2010 08:58 PM
BlazerBrendan
Oct 12, 2008 09:12 PM
