31 10.5 15
Old Feb 19, 2009 | 12:02 AM
89blazer89's Avatar
89blazer89 is an unknown quantity at this point
Default 31 10.5 15
31 10.5 15 will these fit on my stock 89 s10 blazer 4x4 rims? thanks for the help
Old Feb 19, 2009 | 12:06 AM
WolfPack's Avatar
Default RE: 31 10.5 15
they will fit on the rims yes. your truck? no.
Old Feb 19, 2009 | 06:31 AM
bandidolenny's Avatar
Just put'em on and see what happens... but seriously, if your truck has stock suspension then you will have clearance problems with the front tires when turning.
Old Feb 19, 2009 | 06:57 AM
Taymacjack's Avatar
a 2" torsion bar crank and shackles will get you the clearance you need. It will cost you about 30 bucks and some time though...
Old Feb 19, 2009 | 12:10 PM
89blazer89's Avatar
I'm kind of new to the blazer seen so could you give me a finger in the right direction on where the torsion bars are and the shackles and what to do.. thanks for the help guys
Old Feb 19, 2009 | 12:25 PM
I just copied a post made by Jigg a long time ago into the Tech Articles (DIY) section. It has the steps, but none of the cautions. We will need to discuss modification of the article to include this in the DISCUSSION thread for the article.
Old Feb 19, 2009 | 12:45 PM
89blazer89's Avatar
Thanks I looked at that and I think I know how to do it.I'll do it this weekend and let you guys know how it went. Thanks for the help
Old Feb 22, 2009 | 07:28 PM
dober's Avatar
dober is an unknown quantity at this point
will wheel spacers help me or hurt me with 15x10 rims. I believe the back spacing is 3 3/4.
*Combining Consecutive Posts*
is this even possible?
*EDIT by swartlkk* - Please use the EDIT feature to add additional information to your post if another member has yet to reply. Consecutive posting is prohibited by the rules of the forum.
Old Feb 22, 2009 | 08:36 PM
dober's Avatar
Old Feb 22, 2009 | 11:03 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
blocks wont lift these trucks unless you have done a spring over axle conversion in which case fitting 31's would not be an issue at all, you need shackles to lift blocks will only lower it in stock configuration. Take the tbar keys back you wont gain anything just crank your stock keys 1.5" the new keys wont let you get any higher unless you want to be replacing cv's and ball joints constantly.
