31" or 32" tires..... help.
Old Apr 18, 2009 | 01:24 AM
okvortec's Avatar
I'd lift the whole truck, it'd look better and make a more balanced wear/tear ratio from front to back...
Old Apr 18, 2009 | 02:18 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
okvortec-shackles and tbars do lift the whole truck.
shotgunn99- yes 2 inches would be safer than 3inches, but i still think youll have premature wear on ur front end.
Old Apr 18, 2009 | 12:36 PM
okvortec's Avatar
I never said it didnt? I guess I misunderstood him, sounded to me like he only wanted to lift the front of the truck.
Old Apr 18, 2009 | 12:48 PM
Shotgunn99's Avatar
Shotgunn99 is on a distinguished road
Thanks a bunch everyone! ill post pictures once its completed!
Old Apr 18, 2009 | 04:56 PM
bandidolenny's Avatar
I thought you already had a suspension lift.... If you dont, then just crank the torsion bars and see how that works for you. I personally like the front a little higher or at least level. You can always add rear shackles later to bring the rear up.
Old Apr 18, 2009 | 11:30 PM
Shotgunn99's Avatar
ya, i do have new torsion keys and shackles... i just need the tires before i put it all together.
Old May 1, 2009 | 03:53 PM
Big Blaze's Avatar
Big Blaze is an unknown quantity at this point
If you have aftermarket torsion keys and you got 3" of lift out of them, then you are going to destroy your front end. The most you should ever lift the front end by cranking the torsion bars is 2", and even at that height it still greatly accelerates the wear of all of the front end parts.
Old May 1, 2009 | 05:58 PM
mikeinwi's Avatar
1.5" on a tbar crank is the safe limit.
Old May 5, 2009 | 06:13 PM
blazen99's Avatar
blazen99 is on a distinguished road
really helpful thread here. good for newbs like me
Old May 13, 2009 | 12:34 PM
INHUMAN's Avatar
INHUMAN is on a distinguished road
So, i have a question. I have a 98 BlaZeR2 i cranked up my torsion bars 1.5 to 2 inches roughly (dont worry about part wear, im a parts guy :-) ) can i put only 2 inch shackles in the rear to even it up, or are shocks required as well? and in the case thats all i need, can i fit 32's on stock wheels with that amount of lift?
