31s with spacers
Old Jul 2, 2013 | 01:44 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default 31s with spacers
Has anyone used stock 01 2wd rims with spacers and 31s?
Old Jul 2, 2013 | 02:06 PM
Diaita's Avatar
If you are putting it on a 4wd S-series, it's going to rub so bad it won't turn. If it's on a 2wd it will just rub really badly. This is unless you have a 5"+ lift.
Old Jul 2, 2013 | 04:01 PM
rexmburns's Avatar
Super Moderator
Why do you want to run spacers? 2wd rims already have less BS making them stick out further than 4wd rims.
Old Jul 2, 2013 | 06:24 PM
El_Beautor's Avatar
He does have a 2wd, he just forget's to mention that in most of the threads he creates.
Old Jul 3, 2013 | 11:55 AM
01blazer16's Avatar
Yea I do sorry about that. And I wanted them to stick out a little
Old Jul 3, 2013 | 01:12 PM
Diaita's Avatar
The problem is that when you offset the wheels outward from the ball joint centerline, the tire begins to swing around the ball joints instead of rotating on the centerline of the ball joints. When that happens you need more clearance in your fender well to accommodate the greater movement of the tire while steering.
NVANZEE
Tires and Wheels
Sep 18, 2008 10:30 PM
dieseldave_2002
Tires and Wheels
Sep 6, 2008 12:46 PM
RedBlaze
Tires and Wheels
Mar 4, 2008 10:50 PM
Yamitude
Tires and Wheels
23
Feb 13, 2008 01:30 PM
willjones
Lifting Tech
Feb 7, 2008 01:18 PM
