32x11.5x15
Old Jan 11, 2009 | 10:02 PM
DJ 4x4's Avatar
DJ 4x4 is an unknown quantity at this point
Default 32x11.5x15
Anyone running 32x11.5x15 on a rim with the stock 6inch BS? If so could you post some pics. Trying to get an idea of wether or not this would work on my ZR2 with 2inch lift shackles and a little t-bar crank.
Old Jan 11, 2009 | 10:06 PM
WolfPack's Avatar
Default RE: 32x11.5x15
They should work, but you'll probably catch some frame at full lock steering. Also your front flarette might have to be trimmed a bit.
Old Jan 11, 2009 | 10:10 PM
mdehoogh's Avatar
With stock 31" tires, is it really worth the time and effort just to fit tires that are only 1" taller?
Old Jan 11, 2009 | 10:13 PM
WolfPack's Avatar
And 1' wider
Old Jan 12, 2009 | 02:29 PM
DJ 4x4's Avatar
ya it first thought that 1inch doesn't really seem like it would be worth it. But i was looking at one guys truck that had 33x10.5 on it and the tire size was so much diffrent, it looked alot better. would it be good to run a 11.5 wide tire on the stock rim though its width is only 6 right?
Old Jan 12, 2009 | 03:29 PM
greenjimmy's Avatar
greenjimmy is an unknown quantity at this point
thats a big no no. you want to get at least an 8" wide rim to mount 11.5
Old Jan 12, 2009 | 05:11 PM
AJBert's Avatar
Stock rim is 15X7 so you'll be good with putting on a 32X11.5, although rule of thumb is do not go more than 4 inches past your rim width.
I've got 33X10.5 tires on my stock rims and 33X12.5 mudders on a set of 15X8 black steelies for offroad playing. They do make quite a difference of stock 31.
Had to due some trimming front and back with 2' bl, 2' shackle and tbar up about .75'.
Old Jan 13, 2009 | 12:37 AM
DJ 4x4's Avatar
hmm i need to figure out what my rim specs are. Anyone now what rims i have? They were on the truck when i bought it. There american racing rims i know they are 15's and by the looks i'd say stock BS and probably stock width as well. They're the rims that are on my blazer in my sig.
Old Apr 23, 2009 | 10:30 AM
papacope's Avatar
american racing venturas, i have the same wheels but with different backspacing
ckroll98
Tires and Wheels
Jan 3, 2014 08:24 AM
djpaulys
Feb 18, 2011 12:09 PM
byoungquist
Apr 23, 2010 09:04 PM
stevelknievel
Tires and Wheels
18
Aug 11, 2007 05:42 PM
Arthur
Suspension Tech
Apr 18, 2007 09:53 AM
