Suspension Tech Have a question about modifying your suspension? Ask it here.
Looking to clear 32x11.50 tires and aftermarket wheels
Old Mar 22, 2007 | 11:38 PM
Arthur's Avatar
Arthur is an unknown quantity at this point
Default Looking to clear 32x11.50 tires and aftermarket wheels
Right now I have 31x10.50 BF Goodrich All-Terrains on the factory rims. The only suspension work I have done is an add-a-leaf and a torsion crank. This clears the tires really well, but I'm looking to go a little bigger. I plan on getting 32x11.50 tires; they are not only taller but wider. On top of that I plan on putting on RockCrawler wheels which will make the tires stick out a little further. I know that it would rub pretty bad on the set up I have for me right now. My question is would a 2" body lift allow the clearance for the new wheels and tires?
Old Mar 23, 2007 | 12:00 AM
Blazin_Jason's Avatar
Default RE: Looking to clear 32x11.50 tires and aftermarket wheels
What's the reason for wanting to get the 32's? The BL will help but I would think that if you don't have enough backspacing you will hit on the fenders.
Old Mar 23, 2007 | 11:30 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
If you keep the stock rims, trim the fenders, add shackles, and crank your t-bars... you can run those tires.
Otherwise, you're going to rub.
Old Apr 6, 2007 | 12:51 AM
Arthur's Avatar
Ok change of plan... I am going to stick with the 31's for a while, but I still want the new wheels.
With new wheels the 31's will rub, but its going to be easier fitting them than fitting the 32s. I dont know too much about trimming fenders, but I do know that I dont want to do it myself. If I got a new torsion key and cranked up the t-bars the rest of the way do you think I could fit those wheels? If not how much do you think it would cost to pay an offroad shop to trim them for me?
Old Apr 6, 2007 | 08:43 AM
drperry's Avatar
Watch your ball joints and cv axles if you're going to do any off-roading with a maxed out t-bar crank... it increases the wear on those parts by a whole heck of a lot...
Old Apr 7, 2007 | 03:13 PM
Arthur's Avatar
I know about wearing out the parts... I'm just wondering about clearance right now and fender trimming prices right now
Old Apr 8, 2007 | 12:48 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
I plan on clearing 32's with a 2 inch body lift and some fender trimming. But i'm going to wait until i can find a used set for a good price.
Old Apr 18, 2007 | 09:53 AM
mscott03's Avatar
mscott03 is an unknown quantity at this point
Im running on 32's. 2" Body Lift, torsion bar crank about 2", and fenders needed to be cut.
carid
Tires and Wheels
Feb 24, 2015 04:47 AM
ckroll98
Tires and Wheels
Jan 3, 2014 08:24 AM
toobatheviking
Tires and Wheels
May 27, 2011 11:29 PM
92txblazer
Detailing
Aug 13, 2008 11:02 PM
