33" clearance
Old Oct 19, 2008 | 05:29 PM
newbreed's Avatar
newbreed is an unknown quantity at this point
Default 33" clearance
Hey everyone! Well,my name is Joel, This is my first post,I'm new to the site, Me and the family just bought a 2005 Blazer Zr2. Its time to do some things to it already. I'm looking at tires and a local guy is selling 33" BFG ta's. So here is my question.My blazer is Stock right now. Will I be able to through on these tires onto my stock rims and have clearance?Or do I have to go with a smaller tire? Thanks guys!
Joel
Old Oct 19, 2008 | 09:13 PM
WolfPack's Avatar
Default RE: 33" clearance
On the ZR2 you will need 2' of lift at least to run the 33s. BUT...if they are 33x12.50s, you'll still have to do a serious amount of trimming to be able to turn scrub free.
If they are a narrower 33, you will be ok with very minor trimming (if any) and the 2' lift.
Old Oct 19, 2008 | 09:47 PM
newbreed's Avatar
Ouch heh?
What do you guys recomend putting on? A buddy of mine said he can lift the front 1.5 with something in the sus.? then the shackles for 1.5 in the rear, Also getting a 2" body lift. What are you guys recomending?
Old Oct 19, 2008 | 10:39 PM
AJBert's Avatar
I've got a 2000 ZR2 with 2" shackles in the back, 2" BL and just raised the front with about 3/4" Tbar crank. I put the shackles in to get rid of the rear end sag and it brought it up just a bit over the original ride height (hence the tbar crank). With the BL I put on 33X10.5's. I had to do some very minor trimming on the rear flares and have yet to do any on the front. I'll find out very soon if I need to do more when I get it offroad very soon. If you go with 12.5 width plan on doing some trimming up front. Also, be aware, most shops will not put a 12.5 wide tire on a 7" rim. Some will but they tend to be part of the "good ol' boys" club. Not that they are bad folks but I'm guessing there is a reason that others won't.
Old Oct 20, 2008 | 03:39 PM
Hanr3's Avatar
General guide line for tires to rim is 4"-4 1/2". The tire should not exceed 4"-4 1/2" wider then the rim. If you have the factory 7" wide rims, 11"-11 1/2" is the max tire width.
Spectreblazer
Feb 16, 2010 07:44 PM
sparky672
Jan 31, 2010 10:17 AM
Spectreblazer
Jan 14, 2010 08:10 PM
WLB
Engine & Internal
Dec 13, 2009 04:02 PM
Blazer_boy
Aug 25, 2008 02:29 AM
