35”?
Old May 16, 2024 | 11:40 AM
aidenumber07@gmail.com's Avatar
aidenumber07@gmail.com is on a distinguished road
Default 35”?
I was interested in putting either 35” or 33” tires on my 02 Chevy blazer. It has a small lift but not enough to put on 35” tires. How much would it need to be lifted to put 35” tires on?? Is it even possible??
Old May 17, 2024 | 01:16 PM
El_Beautor's Avatar
35's would be huge on an 02 truck with the OEM suspension style, and you'd risk breaking front axle and suspension parts pretty easy. The front diff and CV axles probably wouldn't take the off-road stress very well, unless you're just mall-crawling. You'd need a minimum of 6" lift, plus a body lift, plus a LOT of fender trimming. Now if you wanted to go with a SFA swap... That's a whole different ball game.
33's fit with a 6" lift, although currently I believe Rough Country is the only one who makes a 6" lift. People have done 33's with a 2" suspension lift + a 2" body lift + a significant amount of fender trimming. You just have to be willing to chop quite a bit of metal out of the fenders.
I ran 32's (265/70/17) on both my '96 Blazer (RIP) and my 02 Sonoma with the lift/trimming combo I just mentioned, and I barely clear the fenders when flexing the suspension off-road. As well, for personal drivability reasons, I wouldn't want to go any taller than 31"-32" without changing the axle gear ratio. I have 3.73 gears in mine with the 32's, and I sometimes miss the acceleration I had with shorter tires. I've contemplated getting 4.10 gears to get that back. My winter tires are 31", and the truck accelerates noticeably faster from a stop.
Old May 17, 2024 | 07:25 PM
Thank you for the suggestions. I’m thinking that I will try 32” like you suggested so that I can hopefully avoid fender trimming.
Blazerowner100
Tires and Wheels
30
Oct 21, 2013 04:52 AM
vrryder
Sep 28, 2009 05:11 PM
85kulan
Aug 10, 2009 05:31 PM
blazen4wd
Tires and Wheels
Feb 3, 2009 07:54 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
