35" tires?
Old Jul 6, 2011 | 06:36 PM
VonBerry's Avatar
VonBerry is on a distinguished road
Default 35" tires?
anyone know if i could run 35" tires if i do a 6" suspension lift, 2" body lift, 2" shackles in the rear and a 1.5" t-bar crank in the rear? if so how much trimming would i most likely be needing to do?
Old Jul 12, 2011 | 07:08 AM
Oystein's Avatar
Oystein is on a distinguished road
There would probably still be some trimming left, but more importantly: You'd run the risk of breaking stuff all the time. You should've gotten a K5 if you want something that big, these small guys were not made that solid from the factory.
Could do a solid axle swap, though.
Old Jul 12, 2011 | 08:58 AM
chevytruckdood's Avatar
solid axle swap for the win!!!
Old Jul 12, 2011 | 10:20 AM
NVANZEE's Avatar
you will have to do A LOT of trimming if you actually plan on wheeling it. I have the same setup you listed and my 33s rub. Also depending on the laws in your state it may be too high, I know here in MI the bottom of the bumper cant be more than 26in from the ground and that is exactly what mine is at.
pmzusmc
Apr 19, 2011 05:44 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
