Good old porosity, I lost count of how many Grand Am's we had to service.
Originally Posted by ABN31B
(Post 392740)
:icon_eek: seriously... you have to be a computer.... :icon_eek:
GM actually had to stop making Blazers because their K.Y.L.E. unit had become self aware and knew more than the guys attempting the gen 3 redesign....
(Post 393184)
but not before they had shipped the plans South of the boarder. :icon_laugh: |
:icon_idea1:
he can not speak Portugese...that's why it's safe :icon_hide: |
Hey peeps,
I have had the same issue for years, Stock alloys will leak over time for sure. Its only b/c the seal is dirty etc, every fall before my winter tires and stock rims go back on I get them cleaned and sealed. I also have them put the nitrogen in the tires to help prevent coming out to a flat tire9s)..again... |
^^ :icon_attention:
Originally Posted by swartlkk
(Post 392674)
GM has a technical service bulletin on this very topic. It does happen. Porosity in the casting can allow air to leak out of the rim. This can be diagnosed with a dunk tank and is evidenced by tiny bubbles forming on the surface of the rim between the beads. This isn't something that just starts happening one day though unless the rim has been damaged so...
Quote: Tires/Wheels - Low Tire/Leaking Cast Aluminum Wheels TECHNICAL Bulletin No.: 05-03-10-003F Date: April 27, 2010 Subject: Low Tire Pressure, Leaking Cast Aluminum Wheels (Repair with Adhesive Sealant) Models: 2011 and Prior GM Passenger Cars and Light Duty Trucks (Including Saturn) 2010 and Prior HUMMER H2, H3 2009 and Prior Saab 9-7X with Cast Aluminum Wheels Supercede: This bulletin is being revised to update the model years and the bulletin reference information. Please discard Corporate Bulletin Number 05-03-10-003E (Section 03 - Suspension). Condition Some customers may comment on a low tire pressure condition. Diagnosis of the low tire pressure condition indicates an air leak through the cast aluminum wheel. Cause Porosity in the cast aluminum wheel may be the cause. Notice: This bulletin specifically addresses issues related to the wheel casting that may result in an air leak. For issues related to corrosion of the wheel in service, please refer to Corporate Bulletin Number 08-03-10-006C - Tire Slowly Goes Flat, Tire Air Loss, Low Tire Pressure Warning Light Illuminated, Aluminum Wheel Bead Seat Corrosion (Clean and Resurface Wheel Bead Seat). Correction
Nitrogen :icon_doh: Nothing like :icon_urinal: your money away! But that's a topic covered in another thread. :icon_wink:
I'm going to put helium in my tires to make them lighter and get better milage.
/highjack |
i want to put propane or either in my tires after a local christmas eve tire slasher went through the niegborhood, only got one of my tires but still, if they had been smoking, it would have been worth blowing up the truck, dont know if any flammable gasses are detrimental to rubber though. imagine a actetelne filled tire being knifed by someone smoking, poetic justice right there. never bought into the nitrogen thing.
