backspacing. on my zr2
Old Nov 22, 2008 | 02:05 PM
zr2forlife's Avatar
zr2forlife is an unknown quantity at this point
Default backspacing. on my zr2
ok so i want some rock crawlers. series 51. they have backspacing 3.75" and 4.5". i have some bfg all terrains. right now they are barely rubbing with the stock rims. i want to know what backspacing size you think is best. i want them to sit normal on the truck so they dont rub any more than they do already.
any help!? thanks.
Old Nov 22, 2008 | 10:40 PM
WolfPack's Avatar
Default RE: backspacing. on my zr2
If youve got stock rims and youre rubbing a little, decreasing the backspacing will multiply your problems. Ive got 30x10.50 A/Ts, with 4.5' backspacing, and I rub a little offroad even with my body lift and tbar crank.
Try and find a rim with more backspacing to avoid the trouble.
Old Nov 22, 2008 | 10:55 PM
AJBert's Avatar
You ALWAYS want to stay as close to stock backspacing as possible, which is 6 inches. Unfortunately, there are no rims that I have found, other than stock, that have 6 inches of BS.
That being said, what size tires are you currently running? If they are larger than 31s, that is the reason you are rubbing, providing you have not done any other mods. (Going off your screen name I'm assuming you have a ZR2)
Like Wolfpack said, if you are already rubbing with your stock rims you will rub worse going with less BS. There are a few ZR2 owners that rub on the sway bar with the stock tires/rims, but these are mainly the trucks.
2000Blazer4X4Stock
Tires and Wheels
Apr 6, 2011 09:27 AM
ff_holt1
May 20, 2010 11:41 PM
dirtyjersey
Tires and Wheels
Dec 5, 2006 09:16 PM
jimmyboy
Tires and Wheels
Nov 14, 2006 04:08 PM
SC_Rezahrektion
Suspension Tech
Jan 30, 2006 10:39 PM
