biggest wheels without tranny problems
Old Jul 15, 2008 | 01:40 PM
butters's Avatar
butters is an unknown quantity at this point
Default biggest wheels without tranny problems
ok just thought of it as i have been planning out my blazer. i will be doing atleast a body lift and prolly a susp lift also so thats not an issue my question is what is the biggest i should go hight wise without overworking my engine/tranny and not needing to change anything in the tranny? thansk in advance
Old Jul 15, 2008 | 01:43 PM
Default RE: biggest wheels without tranny problems
You wouldn't be changing anything in the transmission, but rather the gears in the differentials.
The biggest wheel is dependent on a lot of things. To start, what is your gear ratio and tire size stock?
Old Jul 15, 2008 | 05:45 PM
butters's Avatar
wouldnt all or are gear ratios be the same being that (or atleast by year) they woudl be? i have a 96,
Old Jul 15, 2008 | 06:40 PM
rriddle3's Avatar
Not necessarily. For example, the brochure for 2002 shows that all 2WD Blazers got the 3.42 rear end, but 4WD could get 3.42 or 3.73, depending on the model configuration.
Old Jul 15, 2008 | 06:43 PM
butters's Avatar
ok i have a 96 2dr 4wd. if that helps. i will figure it out once i acually get to see it(on vaca) how do i fugure it out though once i have the gearing?
Old Jul 15, 2008 | 08:36 PM
You need to check your RPO code list in your glove box. GU6=3.42 and GT4=3.73
Old Jul 15, 2008 | 09:47 PM
butters's Avatar
thanks, i will get the rest of the info on sat
hoebob69
Tires and Wheels
May 27, 2015 12:19 PM
Alex Yost
May 26, 2013 02:00 PM
AsherHimself
Tires and Wheels
Aug 22, 2009 07:47 PM
shouser
Tires and Wheels
Apr 22, 2009 01:45 AM
juicy_jay_510
Feb 1, 2008 07:35 AM
