BS and wheel size for my truck
ok so i think ive found what i want but not quite sure it will fit. so here it goes. my truck is stock hight in the back but i cranked up the front to level it. can i fit 15x8x4.5bs on my truck with 235/75/15 or 30/9.5/15 on those wheels with my current set up? and does anyone have any pics? it woul be great if i could see em. thanks!!!
Well that rim is going to stick out 2 inches further than stock because it has 1.5" more back space and 1" wider. So with the 235/75 you should be fine but with the 30" tire you might rub when youre turning but it shouldnt be bad.
How to Measure Wheel BackSpace
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel. This measurement is backspace. The above photo shows three wheels with 2",3", & 4" backspace.
bobby099
12-22-2018 09:41 PM
bigdaddykane93
01-27-2016 11:35 PM
er0ck273
07-31-2015 04:10 PM
Ugly_Monkey
31
06-04-2010 03:06 PM
