Camaro SS wheels on Xtreme blazer
Old May 21, 2015 | 11:55 PM
shaun_39702's Avatar
shaun_39702 is on a distinguished road
Default Camaro SS wheels on Xtreme blazer
Will the 2010 SS wheels fit my blazer if so what will I need to do it any help is appreciated
Old May 22, 2015 | 09:28 AM
El_Beautor's Avatar
It certainly can be done, and lots of people do. You will need an adapter though. The 2010 Camaro wheels are a 5x120mm bolt pattern, and the Blazer is 5x4.75" (5x120.7). You will probably need around 2" of backspacing on the adapter too. Your Blazer has 4.5" backspacing where the Camaro has 6.8".
Old May 22, 2015 | 10:05 AM
LeWhite's Avatar
My blazer isnt an Xtreme but it is lowered 2&2in and does have 2011 camaro 18 in wheels. I'd post pictures if I knew how. I made adapters that are 2.25in wide and personally feel that I will cut the front down about a quarter in.
Old May 22, 2015 | 06:47 PM
Is there anywhere I can buy adapters I don't have the means to make adapters also will the wheels stick out past fenders the Xtreme has flares on it so are they wider than a regular blazer
Old May 22, 2015 | 09:32 PM
LeWhite's Avatar
No, the tires dont protrude past the fender with a 2.25 spacer, but they rub ever so slightly at the rear of the inner fender. If you are near Beverly Hills CA I could make you a set.
Old May 23, 2015 | 09:46 AM
No I am in Columbus ms if I bought a 2 in spacer would they still rub or is it the tire size I can buy a set of 2010 SS wheels with tires for 500 so I'm really interested
Old May 26, 2015 | 12:43 AM
LeWhite's Avatar
It will work good! Just make sure that the adapters are hub registered. And be aware that the bolt patterns are slightly different. It will be one slick ride!
04SSBlazer
Mar 25, 2012 02:52 PM
CraigSnedeker
Aug 10, 2011 02:56 PM
rcravincase
Tires and Wheels
Oct 26, 2009 07:22 PM
isenegger
Tires and Wheels
15
Oct 9, 2007 03:40 AM
Yoann
Tires and Wheels
May 12, 2007 03:36 PM
