camaro wheels
Old Oct 27, 2008 | 04:34 PM
silverjeepman45's Avatar
silverjeepman45 is an unknown quantity at this point
Default camaro wheels
ok, i've read the MANY topics on this, but as every size is slightly different, here is the ones im looking to get.
i know they will fit ( 5 x 4.75") but the backspacing issue is what i dont get.
current wheel is:
P235/70/R15 tire
stock blazer alloys
the replacement wheels are:
P215/65/R17 tire
Size : 17" x 9"
Backspacing : 6.875"
Bolt pattern : 4.75"
Material : Aluminum
from what i have read the backspacing on a 4x4 (96) is 6". this makes it a 0.875" difference. now i am guessing that the 0.875" is TOWARD the vechile.
also the width of the rim on the new ones are 9", while i belive the stock rims are 7". this would also move the tire inside edge 1" closer.
so the NEW setup would move the inside of tire edge 1.875" closer?
is this really an issue? the "rubbing" would only be in making a U-Turn, correct? not make a regular turn?
thanks.
Old Oct 29, 2008 | 09:25 AM
Default RE: camaro wheels
anyone?
basically i want to make sure my math is correct, that these would be 1.875" closer to the vechile and if there is rubbing, is it just uturns, or any yurn with them being about 2" closer.
thanks
Old Oct 29, 2008 | 10:13 AM
Since backspacing is the measurement from the back of the rim to the mounting surface, this rim combination will be 0.875" closer to the truck than your current rims. The additional 1.125" (2" - 0.875") rim width will extend out. I would be more worried about the tire. 215 section width is narrow for a 9" wide rim...
Old Oct 29, 2008 | 11:14 AM
z28jeff's Avatar
z28jeff is an unknown quantity at this point
ORIGINAL: swartlkk
I agree. He's gonna need at least a 255 for a 9" rim.
silverjeepman45: use this site to help figure out a proper tire size...
http://www.miata.net/garage/tirecalc.html
Firebird91
Oct 9, 2010 06:02 PM
rcravincase
Tires and Wheels
Oct 26, 2009 07:22 PM
d666
Tires and Wheels
Dec 24, 2008 08:54 PM
isenegger
Tires and Wheels
15
Oct 9, 2007 03:40 AM
Yoann
Tires and Wheels
May 12, 2007 03:36 PM
