caprice steel rims
Old Dec 4, 2007 | 06:00 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default caprice steel rims
i just got a pair of 15 inch black steel rims off a caprice......same everything as the blazer..is their a limit to how big of tires i put on these??? thanks
[/align]
Old Dec 4, 2007 | 06:06 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: caprice steel rims
What year caprice did the wheels come from? If it is newer than '90, then they won't fit. They have a 5x127.0 and ours have 5x120.7.
As for the tires, there is a limit, but it makes a difference on the width. Also if you are lowered, you might have clearance issues if you go too big.
Old Dec 4, 2007 | 06:37 PM
Banned
there from a 93 how do you figure they wont fit?? there 5x4.75 and thats what my blazer is
[/align]
Old Dec 4, 2007 | 07:03 PM
95_4door's Avatar
The newer caprices are 5x127(5x5) and the older caprices are 5x120.7(5x4.75).
The more I think about it, i think they switched the bolt pattern in 94 with the body change.
Old Dec 4, 2007 | 07:09 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
I had 96 impala SS rims on my 78 el camino, 5x4.75. They would be the same as the cappy since they used the same axles and front spindles.
Felon. Id double check to make sure they will fit but ive never heard of a rwd 5 lug GM wheel not fitting another rwd 5 lug pattern, hell you can put mid 80's 5 star iroc wheels on your 96 and they will fit bolt pattern wise.
Old Dec 4, 2007 | 07:29 PM
95_4door's Avatar
Im sorry, I was mistaken.
Old Dec 5, 2007 | 07:27 PM
thegr81's Avatar
Your main concern is backspacing, because of steering and your bumpstops in the rear!! I would do a test fit to make sure they would work.
BlueRyde
Tires and Wheels
Feb 25, 2010 09:52 AM
djdrew010
Dec 28, 2008 07:15 PM
lastcoupe
Street N Strip
23
May 6, 2008 07:39 PM
scott96
Apr 11, 2008 04:11 PM
batzer
Tires and Wheels
Oct 13, 2006 01:21 AM
