confused about wheel size
Old Jun 15, 2009 | 08:27 PM
blazer37's Avatar
blazer37 is an unknown quantity at this point
Default confused about wheel size
ok im looking to get new wheels and im not completely clear on how to determine the whether a wheel will fit or not. i have spent a few hours searching the forums on the subject but the more i read the more confused i become. so i was wondering if someone could tell me which, if any of these wheels will fit on my 2000 4wd blazer with the least amount of modifications.
SIZE B.S. OFFSET C.B. (IN)
18x9 5x150 6 3/8 +35MM 4.346
18x9 5x135 5 3/8 +10MM 3.44
18x9 6x135 6 +25MM 3.44
18x9 5x4.5 5 3/4 +20MM 3.283
18x9 5x5 5 +0MM 3.086
18x9 8x6.5 5 1/2 +12MM 4.795
18x9 6x5.5 4 3/4 -6MM 4.267
18x9 6x5.5 5 1/2 +12MM 4.267
18x9 5x5.5 5 3/4 +19MM 4.267
18x9 8x170 5 1/2 +12MM 4.94
18x9 6x5.5 6 1/8 +30MM 4.267
18x9 8x6.5 4 3/4 -6MM 4.795
18x9 8x170 4 3/4 -6MM 4.94
OR
SIZE B.S. OFFSET BOLT CIRCLE
18x8.5 6 1/8 +35 5-150
18x8.5 5 1/8 +10 5-135
18x8.5 5 3/4 +25 6-135
18x8.5 5 1/8 +10 5-5.0
18x8.5 5 1/4 +12 8-6.5
18x8.5 5 1/8 +10 6-5.5
18x8.5 5 3/4 +25 6-5.5hc
18x8.5 5 1/8 +10 5-5.5
18x8.5 5 1/4 +12 8-170
all of these sizes came off of some web sites so if you are confused my the way i typed them just ask me and ill post links to the sites they came from.
thanks for any help.
Old Jun 15, 2009 | 08:46 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i would try to stay with a rim thats close to 6" backspacing thats the stock BS so the closer you stay to 6" the better off youll be. also with a non lifted 4wd the biggest tire you can run is about 30" so a 245/60/18 should work well on a stock height blazer. im not to sure about how offset works into things so ill let someone else cover that.
Old Jun 15, 2009 | 08:53 PM
blazer37's Avatar
thanks for the reply. i do plan on putting on a 2 inch lift soon so that wont be an issue.
Old Jun 15, 2009 | 09:03 PM
mikeinwi's Avatar
once you get the 2" lift on youll be able to bump your tire size up to 31's(if you wanted to)
Old Jun 15, 2009 | 11:24 PM
bandidolenny's Avatar
Are you putting on street tires or off-road treads? If going the off-road route then keep in mind that a taller side wall will conform better to the terrain and therefore perform better when out on the trail. Plus 15" tires are way cheaper too.
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
chiefbong360
Jan 4, 2010 10:27 AM
wstdintllgnce
Nov 28, 2006 11:24 AM
chevychic4life
Engine & Internal
16
Mar 28, 2006 04:29 PM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
