confussed about offset
Old 01-15-2012, 11:33 PM
Mczuk's Avatar
Mczuk is on a distinguished road
Stock Blazer wheels are (I think) 15x7 +51 offset with 6in backspacing
Old 01-16-2012, 12:33 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Ohh im glad i found this thread, i was confused also. So back spacing and offset are kinda related? if you have a higher backspacing then you will have a lower offset, because the mounting plate gets moved back from dead center of the wheel? or is that backwards? either way that would make sense to me.
Old 01-16-2012, 01:07 AM
tibby's Avatar
Default .
This:
The relative position of the inside face of the center of a wheel to the rest of the wheel is measured two ways.
The offset measurement refers to the distance away -- either outside or inside measurement from the center plane of a wheel. This offset is usually a small number and may be negative or positive depending on the direction of the offset -- towards the outside face or inside face of the wheel.
The backspace measurement is the distance from the inside face of the wheels' center to the edge of the rim (or at the bead) on the inside of the wheel.
sporty_drew
Tires and Wheels
08-09-2009 11:47 PM
95BlazinLT
Tires and Wheels
11-04-2007 05:57 PM
EuroGoldLS
Tires and Wheels
05-27-2007 01:43 PM
schwartz0047
Tires and Wheels
01-08-2007 02:36 AM
9blzr9
12-08-2005 05:33 PM
Quick Reply: confussed about offset
