Corvette C5 wheels
i know the 4x4s never really have issues with any type of backspacing because you guys are lucky SOBs.
But, i found some c5 wheels like GregWs for 200 on craigslist, talked to the guy, said the chrome isn't the greatest but could look great if painted (i'm thinking black of course)..... But here is my problem, the only backspacing i've found that actually looks legitimate says the fronts have 7" of backspacing and the rears have 8. so, does that mean that i can't run them without some crazy a** spacing like 3-4 inches of space for the rear or what? if i can do it with a 2-2.5 inch spacer i'd do it, i'm just a complete noob when it comes to wheels
Other than that though, what would need to be done?
I get my tires mounted and balanced/ rotated for free because my
neighbor owns 8 belle tire stores in the area and i do a lot of work at their house when he's away in Florida or wherever they may be
So you're going to just rotate them side to side or you're going to have a spare set of tires to rotate in and out for both front and rear?
Here's a quick snippet of the info I found:
You may still rub at full lock though.
My brother is running close to 3" adapter/spacers on his 1st Gen 2wd S10 on some GTO wheels and that much of a spacer bothers me, but to each his own.
2wd= 2.25"-3" spacers depending on particular Gen (C4, 5, or 6) and desired distance from fenderwell
PICS ARE A MUST! I toyed with that idea for so long on mine before seeing Z28 rims on a Blazer. If I hadn't done the Z28 rims then I would have done that. so I'm curious as to what it will look like once done.
I'll let you guys know later when i'm not in class for 5 hours a day, coaching little league, and working... work will be a nice break from everything else haha...
Anyways, back on topic, when i do end up doing this, should i completely black it out? should i just dust over it? gloss black? flat black? what do you think?
if any of you remember eurogold (i think) aka Brent Evans or EvansBlue on chevrolet forum, he did this and thats where i got my idea, i like it on his but i think i'll get a different look on mine with the color.
http://chevroletforum.com/forum/pict...pictureid=1256
