extreme rims on a 99 4X4???
Old Aug 13, 2007 | 03:41 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Default RE: extreme rims on a 99 4X4???
ORIGINAL: juscarter
haha, hillbilly said doodie. Hehe.
Whats do you guys think about getting tires that are a few(2-3) inches wider in the back? Know any GOOD sites i could hit up?
Carter -- best advice is to do to the back as you do to the front (yeah, that sounded a little vulgar). I have wide tires now (the Corvette kind). See the size below. They should fit without rubbing, as long as your truck doesn't have any sag from age. If it does, you should be able to lift your truck an inch pretty easily.
Also, be sure to CHECK THE LUGS periodically, to ensure your wheels don't fall off later! In fact, I plan to have longer studs installed in my truck as soon as I am able.
Raph
Old Aug 15, 2007 | 10:15 PM
Hanr3's Avatar
Torque them to 100 foot pounds and recheck after 150 miles. Wheels dont fall off unless the threads are overstretched, which happens when the lug nuts are not properly torqued to spec. Or if they aren't torqued at all.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
blazer206
Lowering Tech
38
Jan 15, 2011 11:19 AM
blazer206
Lowering Tech
Feb 22, 2010 12:32 PM
LuvMyTJ
Dec 18, 2009 12:33 AM
FattyExtreme
Aug 14, 2004 06:02 PM
