General Grabber AT2
Old Oct 17, 2006 | 11:54 PM
Hanr3's Avatar
Default RE: General Grabber AT2
ORIGINAL: DetroitMuscle
...but you need to be careful with em, their contact patch well lack there of is kinda tricky on the road, jsut got to drive it as the weather calls for now...
Not sure what you mean by lack of contact patch. could you elaborate some more?
Old Oct 17, 2006 | 11:55 PM
Kellen's Avatar
Kellen is an unknown quantity at this point
ORIGINAL: tommyd
I paied 530 out the door for 4 BFG mud terrains mounted road force balanced and siped. Though I think the AT's are a little more expensive but the price sounds about right. You should get a ton of milage out of them too.
did you just sipe the center tread blocks?
Old Oct 18, 2006 | 12:01 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
ORIGINAL: Hanr3
there isnt alot of rubber in contact with the road.
Old Oct 18, 2006 | 12:56 AM
Hanr3's Avatar
What would you consider a lot of tread on the road?
Any more tread and it would be a passenger tire.
Old Oct 18, 2006 | 08:17 AM
ORIGINAL: Hanr3
ALL-Terrain not Mud Terrain. Id expect an ALL -TERRAIN to be somewhat of a "passenger" tire. Being its used on AND off road. The grabbers are just as aggressive as the A/T but with alot more rubber touching the ground.
Here is a comparison, I know there is no CONSUMER review but the tech comparison is there.
http://www.tirerack.com/tires/Compar...=0&sortValue=1
Old Oct 18, 2006 | 04:21 PM
tommyd's Avatar
tommyd is an unknown quantity at this point
Yes the center tread blocks are siped. Really helps alot in wet conditions.
Old Oct 18, 2006 | 07:17 PM
Kellen's Avatar
FYI no one can get these in Canada either.
Old Oct 18, 2006 | 08:32 PM
ORIGINAL: Kellen
I was told they were on backorder for atleast 2.5 months a few weeks ago, worldwide.
Old Oct 19, 2006 | 02:17 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
okay, so i've got it down to two tires.... the BFG All-Terrain and the Pro-Comp Mud Terrain (made by Cooper).... help me decide... give me some pros and cons...
Old Oct 19, 2006 | 08:29 AM
All-Terrains are the best for you, unless you are always in the dirt, get the A/T's or check coopers AT tires, they are very nice.
http://www.coopertire.com/html/produ...iscoverer_st_c
My neighbor had the cooper S/T-c's on his 1500 series silverado, he loved em in the mud. Prolly why he moved to Tn on all those acres of venison and mud.
