I want to get WHEEL SPACERS.
Old Sep 19, 2007 | 04:26 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: I want to get WHEEL SPACERS.
swartlkk's (kyle's) bit on wheel spacers
Original: Swartlkk
Here's my bit on spacers... There will be more force on the bearings by pushing the wheels out further. As designed (w/o spacers), the bearings are pretty darn close to the center of the wheel, meaning that the loads will be primarily radial loads (ie straight in towards the axle). When you move the wheel out, you will be creating a moment (twisting) force that isn't present in the stock arrangement. Increased wear can and should be expected. That is just the engineer in me... Had to say it.
With that said, spacers have been used for a very long time with mixed reviews. Many have had little to no trouble from their use. And I would definitely have to recommend hub-centric spacers.
here is the whole thread on "Wheel Spacers, Good or Bad?"
Old Sep 19, 2007 | 07:41 PM
Hanr3's Avatar
If you got a 4x4 and want a wider stance just find a set of aftermarket wheels with 3.75-4" of backspacing or find a set of 2wdr wheels. That will give you a wider stance, however it will also casue your tires to rub hte fender.
Old Sep 19, 2007 | 07:49 PM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
a set of 2wd rims will give a 2' wider stance and not as hard on the moving parts like the spacers
mrprikei
Nov 23, 2011 08:31 PM
calee4nyaboy
Nov 20, 2009 11:48 PM
DetroitMuscle
Dec 16, 2007 02:58 PM
quontush
Apr 21, 2006 08:27 PM
