I wanted to change my tire size.
Old May 25, 2019 | 05:25 PM
strykerld's Avatar
strykerld is on a distinguished road
Default I wanted to change my tire size.
I wanted to change to 225/60/15 instead of the 235/75/15 like what was on it. I figured that it might be a little lower with out lowering it!! I was told I would have to get the computer reprogrammed for the speedo to be correct.
Old May 25, 2019 | 05:41 PM
cleburne red's Avatar
That'll get you about 1.5" lower. Speedo will be off about 5-8mph (it'll read faster than you're really going)
Depending on what year, you'll have to either get the computer reprogrammed, or if it's an early first gen, just change the speedo gear
Old May 25, 2019 | 06:19 PM
Cimmerian's Avatar
Is it costly to get the computer reprogrammed?
Old May 25, 2019 | 06:37 PM
GreenBlazer2002's Avatar
Are you using stock wheels?
Old May 26, 2019 | 03:33 PM
I'm not sure how much it costs to get the computer reprogrammed, but those programmers that plug into the obd port are like $300-$500. They'll do a lot more than tire size, though
Old Jun 3, 2019 | 09:39 PM
To work out an approximate change in the speedometer you can use this comparison tool: https://tiresize.com/calculator/
As for reprogramming the speedometer, another option is an UltraGauge (or similar) tool that plugs into your OBD plug. I use my Ultragage to give me a corrected speedometer reading (I have slightly larger tires) but more importantly it reports to me the transmission fluid temperature. UltraGauge OBDII Scan tool & Information Center
strykerld
Tires and Wheels
Nov 22, 2018 12:17 PM
dano440
Apr 28, 2012 07:28 PM
Buschkj24
Jun 16, 2009 11:11 PM
Doran
Mar 26, 2008 12:54 PM
88s10Blazer
Aug 7, 2006 09:45 AM
