ion 174 wheels backspacing
Old Dec 28, 2011 | 06:14 PM
bowshooter1's Avatar
bowshooter1 is on a distinguished road
Default ion 174 wheels backspacing
hey i ordered these wheels on monday and all it tells me is the offset i was wondering if anybody could tell me what the backspacing on these is so i would know how far they are gonna stick out.
Detroit Wheels 174-5861B Ion 174 Series Wheels
thanks for any help im hoping for a fast reply cuz i get the wheels tommorow and i dont want to have to wait to measure them also how do you like them?
Old Dec 28, 2011 | 07:07 PM
tibby's Avatar
Default .
4.25 inch backspacing I believe.
Old Dec 28, 2011 | 07:54 PM
ok how do you figure it out i know there is a way to figure it out using the rim width and offset.
Old Dec 29, 2011 | 11:10 AM
just went out and measured it and i think its 3.75 bs
Old Dec 29, 2011 | 04:49 PM
billbobagns's Avatar
billbobagns is on a distinguished road
There is a mathematical relationship which is easy to state, but which requires one additional measurement; Thickness of the inside bead-rim of the wheel. Here is why;
Offset is measured in "mm" (yours says -27) and is the distance from the mounting flat surface of the wheel, to the theoretical center of the tire viewed from the front. For a 7" wheel with 0 mm offset, the "Back Spacing" would be 3.5" PLUS the thickness of the outer bead rim. This is because the seven inch measurement is from inside bead rim to inside bead rim, however the "back spacing" is measured from the outside of the inner bead rim. Your wheels say they are 8" inside the bead rims.
If we assume your inner bead rim is .5" then back spacing is equal to (offset in mm)/25.4 plus (wheel width in inches)/2 plus thickness of inner bead rim (we assume .5";
(-27(your wheels)/25.4) + 8"(your wheels)/2 + .5"(rim thickness) = 3.5" back spacing
Hope this is helpful
Old Dec 29, 2011 | 04:57 PM
Thogert's Avatar
^Great, now my brain-cavity hurts.
Old Dec 29, 2011 | 05:44 PM
mdehoogh's Avatar
Very well stated
Here is a good chart that I often post in threads asking about offset. It assumes a half-inch bead thickness.
Old Dec 29, 2011 | 06:29 PM
ok so its about 3.5 inch backspacing? i got them mounted today and they stick way out lol
here is what they look like mounted
here iz the difference between the old and the new
and here iz my new stance it looks awesome
Last edited by bowshooter1; Dec 30, 2011 at 12:29 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 29, 2011 | 07:32 PM
tibby's Avatar
Default .
I was taking a guess at the time and then found a chart similar to the one already posted in here. I stand corrected though.
And your pics didn't show up for some reason. Looking forward to the pictures though.
Old Dec 29, 2011 | 10:51 PM
they show up on my screen lol . ill put them in my albums under new wheels.
they are up now wonder why they didnt show up for you.
