Lets See Some 4x4's!!
Lets see some 4x4's with aftermarket wheels! I'm wanting to get a set of wheels for my new Jimmy for the summer time (I'll be keeping the stockers for winter use) and I'm finding the selection to be a little scarce. How about some of you guys that already have them on yours post them up and share some ideas with all of us? Thanks!!!
RE: Lets See Some 4x4's!!
mybuddy has the same problem w/ his 4x4, wheels for a 2wd will fit yor blazer, only they wiil stick out like 2' more than stock. that what he done. they look pretty good
https://blazerforum.com/upfiles/2948...i234244239.jpg
https://blazerforum.com/upfiles/2948...q425937533.jpg These rims are up for grabs right now if anyone is interested. This was my blazer before I got my truck |
Don't limit yourself to just S10- wheels. Firebirds, Trans Ams, Corevettes all have the same bolt pattern. 5 on 4.75". Check around GM put them on numerous vehicles.
On a 4x4 stick to around 5"-6" of backspacing. When you push thetire out via less backspacing you start pushing the tire into the rear of the front fenders. Even stocksized tires like to rub then. For example 16"x8" Firebird wheels. http://offroadworld.tenmagazines.com...nr3/148300.jpg |
I understand that "some" of the F-Body wheels will fit along with numerous others, its just a matter of which ones. I liked the C6 5spoke wheels and did some math to see if they would fit. I've got the exact measurements at work but I believe the stock backspace is something like 5.67 inches and the C6 wheel offset for 18x8.5in wheels was 6.37, which is too much backspacing and they'll rub.
I'd like to get a set that doesn't stick out much if at all, doesn't rub on the inner fenders, and doesn't require spacers. Although there are believers out there, I'm not confident in the use of spacers on my vehicles. I've never had to use one before in order to make a set of wheels work and I'd just as soon sell a set of wheels that didn't fit and get a different set that fit properly. ceanern, I'm not really the offroading type but I do really like the stance of your Blazer with those wheels on it. Looks nice!!! That said, I use the 4-wheel drive primarily for the winter months here. It's nice in the summer but it also snows very hard during the winter months and sometimes 4wheel drive is a must-have. I'd really like a set of 18x8's or 18x8.5's in chrome with the proper backspace. I'm looking to spend no more than $1000-$1200 on wheels and tires together (used wheels are an option too) which makes the GM takeoffs a viable option as well. I do like the chrome Camaro SS wheels made from 98-02 but those are really the only ones that caught my eye. Any other suggestions??? Thanks! |
Kellen who's themanufacture ofyour wheels. Also are they 15" ,do you know the BS or offset. I'm looking for a set like that,something close to factory spec. BS. Thanks Zero psi I like yoursto but I think the BS would cause me to tare off a flare.
They are ProComp rock crawlers. 15x8, with 6.5 inches backspace i think.
Zero psi.... I love your wheels, where'd you get them???
| All times are GMT -5. The time now is 11:04 AM. |
