Is lift required for 15" camaro rims?
Old Apr 11, 2013 | 05:19 PM
rexazz2's Avatar
Default Is lift required for 15" camaro rims?
I picked up a set of 15' camaro rims and planned on blasting them and powder coating then mounting my 30X9.5X15's
I have done the reading and I think they will fit my 05 base 2dr at stock height without fender trimming
Looking for a yes or no answer from you guys that have these rims
these rims and tires
Old Apr 11, 2013 | 10:23 PM
Blazer2000LT's Avatar
Blazer2000LT is on a distinguished road
i think those camaro rims have 4.5" backspace, you'll jam up against the rear of the front fenders if you try to turn at stock height. just tried it with s10 extreme rims that are the same offset, ended up grabbing firebird rims with 6.875" offset as a temp measure. I think you may be able to do it if you cut out almost all of the rear of the front fender up to the door. Otherwise probably need a body lift. Nice rims though, would look awesome especially in black.
Old Apr 11, 2013 | 10:31 PM
50lb_cat's Avatar
I just got mine back from the powder shop,gonna get them on this weekend and i will let you know, mine is a four door, 4x4.
Old Apr 12, 2013 | 04:39 AM
rexazz2's Avatar
yes Black or a dark graphite
please do , I can not have down time at this time of year
Old Apr 15, 2013 | 07:30 PM
rexazz2's Avatar
50lb'r , did you try yours ?
Old Apr 15, 2013 | 08:20 PM
chris015's Avatar
it wont rub at all with 30" tires
Old Apr 16, 2013 | 12:23 PM
tibby's Avatar
Default .
Not true. Some blazers will rub with only 30s because the backspacing is so low. I know I had to trim a decent bit to make 31s fit. They will probably slightly rub with 30s. But this matter is really pretty subjective because no blazer is the same. The aging process could change how the torsion bars sit, different packages that blazers came with... You never know until you try, that's all I have to say.
Old Apr 16, 2013 | 06:20 PM
gitch93's Avatar
gitch93 is on a distinguished road
like i was saying rex majority of the time u need to lift it i got offset rims on my 4 door and run 31s and had massive fender trimming. my tbars are also sagging alot and gonna install new zr2 ones to correct the issue. u can probably get away with the tires and rims with a tbar crank
Old Apr 16, 2013 | 06:48 PM
50lb_cat's Avatar
Mine fit ok, no trimming required, almost rubs lol
1998LT
Tires and Wheels
Sep 19, 2010 10:25 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
