lowering blazer on 20's?
Old Feb 27, 2006 | 04:55 PM
onebadblazer97's Avatar
onebadblazer97 is an unknown quantity at this point
Default lowering blazer on 20's?
I have a 97 blazer 2wd 4 door and im gonna put 20's on it soon with 245/40 tires. Can i lower it 1" in the front and 2" in the back without having to modify the wheel wells or the fender up front? Can I even fit the wheels without modification? Thanks in advance for any replies.
Old Feb 27, 2006 | 09:41 PM
silverjimmy95's Avatar
silverjimmy95 is an unknown quantity at this point
Default RE: lowering blazer on 20's?
I got 245's with 20's on my jimmy an i got a 4 inch drop i dont rub[sm=yeahsmile.gif]
Old Feb 27, 2006 | 09:44 PM
Thanks silver, another question,how wide are your wheels?
Old Feb 28, 2006 | 12:41 AM
i wanna say 8 or 9 in there, not sure, i'll find out for sure tho for you, if you go to a used tire place an find some reasonably priced 275s that have half the tread on them, i'll trade you my 245 that have atleast 75%..these roads suck in SC man..i just havent any luck. but im sure you got the money for brand new rubber anyways so that wouldnt work out, haha..sorry rambling, but i'll get the whole specs for you in the morning.
Old Feb 28, 2006 | 01:15 AM
2001blazer's Avatar
2001blazer is an unknown quantity at this point
u can fit up to 255s on the truck from the way it sounds and have clearance for all turning but i also heard that 8 1/2 in. wide rims are the widest u can go not totally sure on that though. im gunna go with 20x8.5 rims and 255/45r20 tires should fill the wheelwell nicely itll be like littledan911's truck i like that look cuz up in minnesota we have pretty nice size winters and i need to use my stock tires in the winter so i dont want to lower it
Old Feb 28, 2006 | 10:22 AM
LittleDan911's Avatar
LittleDan911 is an unknown quantity at this point
Yeah 255/45R20 Is As Big As You Can Go Stock But I'm Gona Try ANd Lower It ..... 2/2 Mayb 3/3
Old Mar 6, 2006 | 02:38 AM
blazerxtreme1's Avatar
blazerxtreme1 is an unknown quantity at this point
I have 20s on my extreme 245/35/20 and i only rub on sharp turns so i know you'll be fine
Old Mar 19, 2006 | 01:40 PM
DaNK 305's Avatar
DaNK 305 is an unknown quantity at this point
ya you will be fine..
hotrodclutch
Lowering Tech
Apr 24, 2011 05:05 AM
vagnozzi
Lowering Tech
May 12, 2008 12:52 AM
speeddemon560
Suspension Tech
Feb 6, 2007 04:18 PM
white04blazr
Suspension Tech
Oct 5, 2005 11:06 PM
choi_kid
Suspension Tech
Apr 26, 2005 02:17 AM
