Need help with size
what are the stock sizes for the ZR2
i know it says on the tire but i dont understand the numbers as to what it meens...
like what are the tire and rim size is what i need to know so that when it comes time that i have money to do so i can get the right ones
ProComp Xtreme Steel Wheels Series 152
with
BFG Mud Terrain T/A Tires
and then is there some kind of math equation or something if i were going to do a 6 inch suspension lift as to say what size i would need then?
with
Whatever you do, don't buy from them. Jigg has em 20 bucks/rim cheaper! Synergy Offroad
As for the sizes, youre lookin for a 15' rim, 5x4.75 bolt pattern, and backspacing is a matter of preference. As for tire size, I thought ZR2s use 31x10.50s, but I'm not positive on that.
even though it has been explained countless times, i will do so again.
if the tire size is (LT/P)235/75r15
LT stands for light truck and P stands for passenger
1st number (235) width in mm of the tread. in this case, the tread would be 235mm, 23.5cm, or 9.252" (2.54cm = 1")
2nd number (75) is the ratio of the tread width to the sidewall height. in this case, the sidewall is 75% as wide as the tread. 0.75 x 235 = 176.25mm. this means that from the top of the rim to the top of the tire is 176.25mm, 17.625cm, or 6.939"
3rd number (15) is the diameter of the rim
now, to put it into context, Rim Height + (sidewall x2) = total height of tire. 15 + (2 x 6.939) = 28.878... this means a tire that is 235/75r15 is 28.878" tall and 9.252" wide
another common measurements would be, say 31x10.5x15... 31" tall, 10.5" wide and a 15" rim
the tire size for your ZR2 will not be in millimeters (ex. 235/75/r15) it will be in inches (ex. 31x10.5x15) the stock tires are 31x10.50x15... you will need a 15 inch rim with 5 on 4.75 bolts pattern and a 6 inch backspacing to replace the stockers... a popular upgrade is a rim with 4.5 inches of backspacing... when you do the swap remember to POST PICS!!!!!
(you can find a 31x10.50 equivalent in millimeters, it's just easier to buy a 31x10.50.... most tire shops regularly stock this size as it is a stock option on Chevy S-series ZR2's and also a stock size on late model ford, chevy, dodge, and toyota pickups..)
ORIGINAL: WolfPack
balljoints, tie rod ends, end links, inner fender bolts and a few more parts that take the brunt of it. Sure it wont happen overnight, but it will happen, and at times it will become painfully obvious. No chick wants to hear your truck rubble and feel her feet shake when you make turns. The meatier the tire, the worse the rumble and shake. Back spacing is important on our trucks.
If your lifting the truck, or going to trim the fenders, or move the body away fromt eh tire in another fashion? Great, run what you want and take care of the rest. Post pics.
finnaly my B day is fast approaching so I can do an upgrade and it might be the tires
but there is either deer guared / lights or intake and exaust i have to choose unless i can get the rims for cheap then i can both the rims and the deer guared / lights or the exaust and intake
BackwoodsBogger14
Headers, Intake, & Exhaust
Oct 8, 2013 12:20 AM
jtlockwood88
Feb 5, 2011 07:02 PM
rick465
Aug 25, 2006 09:37 PM
