Need help with wheel size!
Old Jan 22, 2013 | 05:55 PM
whitlow719's Avatar
whitlow719 is on a distinguished road
Default Need help with wheel size!
I have a 99 Blazer LS 4X4 4dr, and I'm trying to find some new wheels for it, but I don't know what the backspacing is. All I know is the diameter (15'') and the bolt pattern (5-4.5). What would the backspacing be? Also, what would the wheel size be? 15x8 or 15x10? My tire size is P235/70R15. I am looking at ProComp Rockcrawler wheels like these.
Series 97, 15x8 with 5 on 4.5 Bolt Pattern - Gloss Black
Old Jan 23, 2013 | 10:04 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
ur wheels should be a 15x7 with a bolt pattern of 5 on 4.75. but i could be wrong. backspacing should b sumwhere around 3.5". but im not 100% sure.
Old Jan 24, 2013 | 09:34 AM
Jamaroon's Avatar
Stock wheels are 15x7, 6" backspacing, bolt pattern of 5x4.75.
Straying from stock specs means higher chance of rubbing. Going to a 15x8 with 4.5" backspacing means the tires are going to stick out 2" further than stock and could rub on the fender and/or bumper while turning.
Old Jan 24, 2013 | 10:02 AM
rexmburns's Avatar
Super Moderator
Yeah you don't want 5x4.5 spacing you want 5x4.75! 6" is stock and the most you will find in the pro comps I believe is 4.5". This will work but like Jam said you increase your chances of rubbing. Also get a 15x7 with the tire size you want to run or your rim will be to wide for the tire and it will look funny.
Old Jan 24, 2013 | 10:15 PM
whitlow719's Avatar
could i just use these with my stock tires right now then get another set later?
Series 98 Rock Crawler - Gloss Black Monster Mod Wheel
Old Jan 25, 2013 | 07:10 AM
Jamaroon's Avatar
Yup, those are the ones you want. I don't know about tires clearing though. Someone else may have better insight into that.
Why would you get another set later?
Old Jan 26, 2013 | 09:46 AM
whitlow719's Avatar
I meant set of tires not wheels
KidBlazer
Tires and Wheels
Feb 7, 2013 01:26 PM
ArcherXring
Tires and Wheels
Jan 14, 2013 07:45 AM
philipbolek
15
Jan 23, 2012 07:08 AM
bigfish
Tires and Wheels
Jan 18, 2010 12:10 PM
mx_579
Tires and Wheels
Sep 18, 2009 11:36 AM
