new rims
Old Dec 25, 2010 | 05:08 PM
Crispy23's Avatar
Crispy23 is on a distinguished road
Default new rims
got some black american racing rims and they have some rust. what kind of sand paper should i use because i want to repaint them eather flat black or gloss black.
Old Dec 25, 2010 | 08:50 PM
old skool luvr's Avatar
simple.
use some 120 to knock down the rust. then follow up with some 320 to get rid of the coarse sanding marks.
then scruff the whole wheel with a red Scotchbrite pad. clean with all the usual prep stuff for painting.
Old Dec 25, 2010 | 09:41 PM
Benedict1337's Avatar
Priming helps out a lot on wheels the paint holds up much better than if u just paint it. I used 60 grit and then 120 grit and finally some 300 grit to smooth it out. I used red primer just so you know you have enough paint on top.
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
JST4SHO
The Chop Shop
Mar 2, 2011 11:16 PM
zero psi
Tires and Wheels
21
Nov 8, 2008 05:30 PM
splat
Mar 23, 2007 07:08 PM
evan_j
Tires and Wheels
Oct 3, 2005 04:52 PM
