offset and back spacing the same thing?
Old Apr 25, 2010 | 05:25 PM
brian400ex's Avatar
brian400ex is on a distinguished road
Default offset and back spacing the same thing?
Trying to find wheels and tires to fit on my stock 2003 4x4 blazer. 17" or 18". I know a 30" tires should be good. 5x4 3/4 bolt pattern and a 6" backspacing. what about offset? is offset the same as back spacing?
Old Apr 25, 2010 | 05:37 PM
No, they are not the same. Offset is the distance from the center of the rim to the wheel mounting surface while back spacing is the distance from the back of the rim to the wheel mounting surface.
Old Apr 25, 2010 | 09:11 PM
AJBert's Avatar
Look into Camaro/Firebird or C5 Corvette rims to find what you are looking for, though you may have to run a spacer as some of them are a bit over 6" of backspacing.
Old Apr 26, 2010 | 11:15 AM
brian400ex's Avatar
if you change the offset the backspacing has to change right?
Old Apr 26, 2010 | 12:10 PM
If the rim width stays the same, yes.
Old Apr 26, 2010 | 04:34 PM
brian400ex's Avatar
so if you have 6" backspacing then the offset will always be the same. im confused.
Old Apr 27, 2010 | 06:21 AM
Go to TireRack.com and search for backspacing and/or offset. They have a complete description with a picture to explain it. Heck, you can search here as well. I know I have posted the picture before as well...
This should explain things better:
ILoudNLow
Tires and Wheels
Mar 31, 2012 02:40 PM
sporty_drew
Tires and Wheels
Aug 9, 2009 11:47 PM
kiwiblazer
Tires and Wheels
Jun 26, 2009 11:25 PM
paxlineman
Tires and Wheels
Jun 10, 2009 08:57 PM
Cavalier z24
Tires and Wheels
Mar 22, 2009 02:22 PM
