Offset a cure to large tire body rub?
I’m looking to put 255/85/16s on a generation I 4-door S10 Blazer; this is a 33” tire that is 10” wide.
I’ve read in several places that 33s will fit on an S-10 with a few inches of body lift and some serious fender trimming. I’ve read elsewhere (on this forum) however, that to avoid body rub a suspension lift is also required.
I do not want to do a suspension lift, but I’m fine with a body lift and fender trimming. So my questions are:
1) Is it possible to body trim and body lift my way to no rubbing with 255/85/16s?
2)If not, could I cure this by using wheels with a different off set (since I’ll be buying 16’ rims anyways)? Would I be causing a bunch of other problems (steering issues) buy using wheels with a different offset?
Thanks! You helps is much appreciated.
Dan 128
Jun 10, 2011 11:58 PM
