Ok to change two tires?
Old Jan 5, 2011 | 07:24 AM
qsecofr's Avatar
qsecofr is on a distinguished road
Default Ok to change two tires?
Hi,
This is my first post here.
I have tried to use the search function to get an answer to my question, but i failed. Maybe i did lousy serches ; )
I have a Blazer LT 1997 4wd that i have blown a front tire on. The tire is beyond repair.
The question is if it's ok to buy two new tires that has the same size as the old ones and keep two half worn tires?
i mean if it's bad for the transmission to have different worn tires on the axels?
If so, is it only bad when i have 4wd in? And ok to drive with in 2wd?
Or is it no problem at all with this type of 4wd?
Thanks a lot from Sweden.
7qsec
Old Jan 5, 2011 | 08:21 AM
Benedict1337's Avatar
if you get the same tires as you had, you should be ok, but make sure you get the same tires because if you get a different brand in the same size there may be size differences even if they say they are the same size, each company varies on size a little.
Old Jan 5, 2011 | 05:05 PM
84BlazerS10's Avatar
Also, put the new tires in the rear.
Old Jan 7, 2011 | 12:49 AM
qsecofr's Avatar
Ok, thank you.
I just got a chance to buy four used tires in good condition quite cheep.
I think i will go with that just to be sure.
/qsec
Hormisdas
Nov 27, 2012 09:42 PM
The_Beast
Mar 27, 2010 06:32 PM
gmoney30
Jan 4, 2010 11:08 PM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
Blaze1forU
Tires and Wheels
Mar 24, 2007 07:18 PM
