quick offset question
Old Sep 15, 2011 | 09:42 PM
racer1044's Avatar
racer1044 is on a distinguished road
Default quick offset question
So before I pull the trigger on these wheels. I have everything here for my truck but the wheels. 2 inch shackles slight tbar crank 2inch BL. I have a set of 31x10.50 a/t tires.
I want the wheels to be offset more then stock but nothing to wild. My plan is to run a 15x7 wheel with 3.75 inch backspacing. So if im correct that would put the offset at -6. Which would stick the tires out around almost 3 inches further than stock 4wd wheels. Is that correct?
Thanks for the help in advance.
Old Sep 15, 2011 | 10:03 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
My wheels are exactly those specs and yes, you can run a 31-1050 on them.
Before
After
Old Sep 16, 2011 | 05:54 PM
racer1044's Avatar
Thanks for the help man. That pic helps a lot. With that backspacing I am gonna get just the look I want with the wheel and tire combo.
Old Sep 16, 2011 | 09:43 PM
mdehoogh's Avatar
These are 31's with 4" BS (0 offset). Yours will stick out just a little bit extra. Be sure to post pics once you get everything done
Old Sep 19, 2011 | 12:01 PM
racer1044's Avatar
I will def post some pics up. Ill be taking pics of the progress of the truck and make a build thread shortly. Gonna wait for everything to arrive first. I ordered the body lift and wheels the other day. I already have the tires and shackles here. Today I doing lower ball joints and outer tie rod ends. After the lift goes on I have some plate metal and will start work on the off road front bumper as well as truck bed lining the out side and underneath of the truck.
Kipper667
Aug 13, 2014 05:57 PM
sporty_drew
Tires and Wheels
Aug 9, 2009 11:47 PM
oktain
Tires and Wheels
May 1, 2009 10:33 AM
PhatDRock
Tires and Wheels
15
Jun 27, 2008 09:45 PM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
