Rear wheel spacers…
Old Apr 12, 2025 | 07:19 PM
FMFDOC's Avatar
FMFDOC is on a distinguished road
Default Rear wheel spacers…
Evening gents,
I realized the rear axle on my 87 K5 Blazer is narrower than the front… has anybody put spacers on the rear wheels? And if so, what size did you have to put to even them up?
It looks goofy as is.
Old Apr 14, 2025 | 10:02 AM
El_Beautor's Avatar
Don't have a K5, but I've used spacers on my Blazer and Sonoma to make the front & rear wheel track the same width for 10 years. For the K5 you'll have to find the axle width from wheel mounting surface to wheel mounting surface. The difference front to year will help you pick what size spacers to even it out.
The biggest thing to worry about with spacers is making sure that you properly torque, and then retorque the spacer nuts exactly the same way you're supposed to do when you remove a tire. You put them on and torque them to spec. Then after driving for about 100km you have to remove the tires, retorque the spacer lug nuts, then re-install your tires. This process is only necessary each time you remove the spacers.
Edit to add: For those who don't use the metric system, 100km is around 100 football fields, or 67 aircraft carriers.
Last edited by El_Beautor; Apr 14, 2025 at 10:18 AM. Reason: add metric conversion
christine_208
Tires and Wheels
14
Jun 18, 2018 02:41 PM
jmparker82
Tires and Wheels
May 26, 2014 01:17 PM
Tinted
Dec 24, 2011 01:56 PM
dimmuborgir6nik6
Mar 2, 2009 06:45 AM
bksowers1
Tires and Wheels
Nov 19, 2008 08:27 PM
