refurbishing rims
Old May 12, 2010 | 05:55 PM
Meganutter's Avatar
Meganutter is on a distinguished road
Default refurbishing rims
Hello,
As i mentioned in my introduction post i want to polish up my truck, now there are some things i can find but this one leaves me in the dark.
I have some sort of rust-ish stuff on the rims of my truck, i would like to make them look clean and spiffy again. What would be the best practice without changing the rims? i thought a lot of polishing with wax but i would like some more opinions on it if you dont mind.
wheel:
http://i44.tinypic.com/vxg7z6.jpg
close-up:
http://i44.tinypic.com/2uf94dl.jpg
Thanks in advance
- Mega
Last edited by Meganutter; May 13, 2010 at 02:12 AM. Reason: wrong link in the post
Old May 12, 2010 | 07:15 PM
taba5's Avatar
taba5 is on a distinguished road
the only real way to get through that would be to have them un-mounted (tires) and have them sand/bead blasted to remove the clear coating.
The clear has chipped away in the "pitted" spots and the elements have eaten away at the raw aluminum.
You could get rid of some of the darkening with some good quality wheel acid (rim cleaner) and possibly take a mini buffer(dremmel) with some good metal polish and bring some more of that out....
other than that, option 2 would to be to paint them... I did this with both of my bravadas because the rims were shotty in spots so a couple coats of black did well
Old May 13, 2010 | 02:14 AM
Meganutter's Avatar
and if you want to paint them, could you just tape off the 4x4 and take some sandpaper to it and when its smooth paint over it?
or is it still possible to fix them up using a dremel and then clear coating over it?
Old May 13, 2010 | 05:18 AM
taba5's Avatar
you could dremel it and then clear it, but be careful on what product you use as clear will not stick to a "wax"
Old May 15, 2010 | 07:18 PM
eisterd's Avatar
eisterd is on a distinguished road
I stripped the clear off with aircraft remover (stripper) and am In the middle of polishing with a powerball. Looks good so far!
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
zero psi
Tires and Wheels
Apr 22, 2005 11:54 PM
Raider Fish
Tires and Wheels
Apr 4, 2005 02:38 PM
BlazerChick
Tires and Wheels
Dec 24, 2004 09:01 AM
01xtreme
Suspension Tech
Sep 14, 2004 04:31 AM
