the right wheels, rims for the right look!
Old Oct 11, 2009 | 09:05 AM
Sisk's Avatar
Originally Posted by kikkegek
So if I am correct, I could also put tires with a bigger diametre and greater width, and still keep the same rims on my Blazer?
Absolutely. Just make sure you get the right R size (rim size) tire...which is 15. Also, don't go above a 30" tire since you will run into rubbing issues on the frame and sway bar.
Old Oct 11, 2009 | 09:39 AM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
Gotta ask, are those factory flares on that? And what are the things on the top of the front bumper?
Old Oct 11, 2009 | 03:08 PM
kikkegek's Avatar
kikkegek is on a distinguished road
flares? if you mean the things on our fenders. I really dont know! You like them?
the things on the front bumpers spray washer fluid when the lights are on and I spray the front window. They clean the lights!
this is what we would like:
they dont need to be mudd wheels, but the size is right!
Old Oct 11, 2009 | 04:14 PM
Zeeke98's Avatar
I thought maybe they were headlight washers since most European countries require them. We don't get those nice flares on the 4 doors here. I would have loved a set when I had my 4 door.
Old Oct 11, 2009 | 04:22 PM
okvortec's Avatar
Kikkegek just to clarify.. You can get any tire you like for any type of rim, as long as the (R) size of the tire is the same size of your rim. For example, your rim is 15" tall and 7" or 8" wide. As Alex (Sisk) said, you can go up to a 30x9.5R15 at stock height on Blazers without getting a lift. But seeing as how the 30x9.5 tire is obviously 30" tall (above stock specifications), you will not want to go any wider of a tire then 9.5" without a lift or you may see some rubbing issues.
To sum it up, get some 30x9.5R15 All-Terrain tires and some 1" or 2" adapters and you should be happy
Old Oct 11, 2009 | 05:21 PM
Sisk's Avatar
Those flares would be the equivalent of our ZR2 flares here. They come stock on ZR2's.
Old Oct 11, 2009 | 07:40 PM
Zeeke98's Avatar
Uhh yeah, I know what a ZR2 is, but there is no 4 door ZR2 and that is a stock height 4x4 4 door with the flares. I wonder why they were never offered as an option on US trucks.
Old Oct 12, 2009 | 12:04 AM
kikkegek's Avatar
they are indeed, thats what I tried to explain. They are headlight washers.
Old Oct 12, 2009 | 12:07 AM
kikkegek's Avatar
oke. But 9,5 x 25,4 = 241,3 mm width. We now have 235 tires, so a 9,5 would not bring a noticeable difference. I might want to look into those adapters, but I am still a little bit afraid about the stories of unequal wearing of the bearings and other stuff. I cannot find anything about it, to confirm that 1 or 2" adapters will not mather. got any site I can read?
Old Oct 12, 2009 | 12:18 AM
BlaziNator's Avatar
BlaziNator is on a distinguished road
