rim and tire sizes?
Old Jan 6, 2011 | 07:13 PM
walker99's Avatar
walker99 is on a distinguished road
Default rim and tire sizes?
im looking into running a bigger rim and tire combination. with out bodying a suspension lift or body lift. im just wondering what tire size would keep the same or lil bigger size compared to stock.. i wanna run a 16-18 rim.
thanks
Old Jan 6, 2011 | 09:03 PM
ABN31B's Avatar
or search...
i think 265/65r17 is close to the same size off memory... maybe
Old Jan 7, 2011 | 01:11 AM
old skool luvr's Avatar
Originally Posted by ABN31B
or search...
sorry Curtis. not. even. close!
that tire size is just over 30.5" tall, knocking out your speedo 8.6%. never mind barely being able to fit in the wheel well.
the largest tire you can run on stock suspension/no BL is either.......
245/70/R16 (29.50" diameter),
245/65/R17 (29.53" diameter),
245/60/R18 (29.57" diameter).
i know this will work since i have a set of 17's with that size of tire on them for my '98, which is currently stock suspension, and these fit. just.
they drive & turn alright, but the rear edge of the inner fender well does rub-slightly- when turning into driveways. not too bad if you go slowly, but for the couple of days i ran them last Summer, i found it to be quite a PITA. plus i didn't want to risk beating the fenders up.
here's a pic to give you an idea of what kind of space you have,
hope that helped you out brother.
***edit*** i forgot to mention that these tires are roughly only 30 to 35% tread, so they're a little under the 29.5" diameter.
Last edited by old skool luvr; Jan 7, 2011 at 01:17 AM. Reason: forgot something critical.
Old Jan 7, 2011 | 01:36 AM
ABN31B's Avatar
bah i was close for memory
Old Jan 16, 2011 | 06:07 PM
walker99's Avatar
ok so i just got a set of 18s, the tires right now on them are 235/40/18, im just wondering which tire would a 30" diameter, i wanna run a bigger width than 235, prob 255-265. just wondering what the profile would be to get me to the 30" diameter
thanks guy
ben
Old Jan 16, 2011 | 07:44 PM
closer's Avatar
closer is on a distinguished road
Let me see if this link works. This is what I use to figure out overall sizes of metric tires. http://www.rimsntires.com/rt_specs.jsp
Old Jan 16, 2011 | 09:11 PM
mdehoogh's Avatar
Awesome link! Thanks for posting that
walker, 255/55/18 is pretty close. here's another link for comparing tire sizes http://www.miata.net/garage/tirecalc.html
Old Jan 16, 2011 | 09:49 PM
actually.........that tire is just over 29" diameter.
a 255/60/R18 will net you a 30" tire. and it'll knock out your speedo 6.96%
@ Matt: i found that Miata calculator you linked to, to be kind-of a PITA to use. it seemed to take forever to load. but that could just be my dino of a desktop.
personally, i've always used 1010tires calcualtor.
evuldrporkchop
Mar 4, 2013 01:20 AM
tony991
Tires and Wheels
Jan 15, 2010 01:31 AM
Ryanesque
Tires and Wheels
Oct 22, 2008 06:22 AM
ncmudblazer
Tires and Wheels
Sep 16, 2008 11:29 AM
Jharper
Tires and Wheels
Nov 14, 2007 08:48 PM
