Rims for 4wd blazer
Rims for 4wd blazer
These are the rims their 22x9 with a 5x4.75 bolt pattern
They were on this truck before
I have a 93 4dr S10 Blazer 4wd I want to put rims on it would these rims fit it is the same bolt pattern but they are 9 inches wide would they stick out i had 8.5 width rims before and they stuck out any feedback would be greatly appreciated
If I’m not mistaken, they should work fine. While 8.5’s may stuck out a bit, going to 9”a isn’t going to be much of a noticeable difference in appearance. Going on the assumption that you’ve had said size wheels on the vehicle before, you shouldn’t have much trouble if any at all. Just be cautious your first trip, and for the following 100 miles or so… Should be good to go..
