16inch camaro rims
Old Dec 2, 2005 | 10:36 PM
Jhop16's Avatar
Jhop16 is an unknown quantity at this point
Default 16inch camaro rims
hey would 16 inch camaro rims fit on my 92 blazer? i figured they would becuz theyre both chevys and people put camaro rims on them all the time, BUT doesnt 4wd require special rims for the front?? ...
Old Dec 2, 2005 | 11:47 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: 16inch camaro rims
i have heard they'll fit, but you'd be better off measuring backspacing on them to be sure.
Old Dec 3, 2005 | 09:40 AM
2000ZR2's Avatar
2000ZR2 is an unknown quantity at this point
you better check the bolt pattern offset 5(lug)x 1something im not sure on the exact but a rim shop should have that stuff on hand but some rims are made for rear wheel, front wheel and all wheel but your staying away from oversized rims so you should be fine
Old Dec 3, 2005 | 12:46 PM
Hanr3's Avatar
I have a set of Firebird rims on my '87 S10-blazer. They have like 6" backspacing. The rims are 16x8". Our lug pattern is 5x4.75". Camaros, Firebirds, and a few others will fit. Like they said check the backspacing and make sure the bolt patern is 5x4.75".
chevymobbin
Tires and Wheels
17
May 29, 2012 10:10 PM
NEW YORK BOY
Tires and Wheels
May 16, 2011 10:25 PM
jackdough
Tires and Wheels
Apr 7, 2011 08:01 PM
willjones
Tires and Wheels
Feb 20, 2009 07:12 AM
jellyphish97
Tires and Wheels
Oct 17, 2008 10:24 PM
