Hello all am a member of S10 forums so since I just bought a Blazer figured I’d join.
I have a 89 2 Door 4x4 and if I read correctly I can use corvette wheels?
if so do I need spacers?
thank you for answering I know a common question.
glenn
glenn
5x4.75 wheels are the ticket.
Chevy/Pontiac used them pretty often. You're running a 4x4, so some positive off set is going to keep your wheels/tires from sticking out. Iroc rims have a ton of positive offset, the right lug pattern and are 16x8 so you can play with tires from rubber band up to thick old meats... whatever you feel looks best.
I have the '87-'89 style gold/grey Irocs on my truck, but it's a beatstick, not lowered and far from pretty.
Maybe go with the wired-spoke style early 90's caprice/impala wheels and powder coat them something complimentary before tucking tires on em 🤔
Hope that helps...
Hope that helps...
Hope that helps...
I ended buying a set of Corvette Sawblades… I’ll post pictures once there on. Thank you for any help! Originally Posted by ABN31B
5x4.75 wheels are the ticket.Chevy/Pontiac used them pretty often. You're running a 4x4, so some positive off set is going to keep your wheels/tires from sticking out. Iroc rims have a ton of positive offset, the right lug pattern and are 16x8 so you can play with tires from rubber band up to thick old meats... whatever you feel looks best.
Hope that helps...
I run 4th gen Camaro rims on my Blazer. Those are still the 5x4.75" pattern. I run 16x8's for my winter tires and 17x9's for the summer tires.
Most 4th gen Camaro rims have 6.8" backspace, compared to the 6" on the factory S-series 4x4 rims, so I run the wider ZR2 rear axle along with 1.5" spacers on the front. This results in my stance being about 1.5-2" wider overall vs the factory due to wider rims and wider tires.
