Spacing the wheels.
Old Nov 30, 2008 | 05:20 PM
00BlackBlzr's Avatar
00BlackBlzr is an unknown quantity at this point
Default Spacing the wheels.
Hi, i have read previous thread about that subjet and i'm still asking myself
that if i space the wheels front/back if i will still see the difference between
the two like the back end will still be narrower then the the front wheels and
will it dammage something or prematuraly used the tires 'cause im with orginal
suspension and wheels???
Thank you!, '00BlackBlzr
Old Nov 30, 2008 | 05:33 PM
Default RE: Spacing the wheels.
If you space them the same, how do you expect the difference to be any more or less? You will need thicker spacers in the back if you wanted to make the track width the same front to back.
There will be increased load on the wheel bearings by spacing the wheels out further. Results vary concerning increased wear and it really is hit or miss.
Spacing out the wheels should have no impact on the tires themselves if everything in the alignment is proper to begin with.
Old Nov 30, 2008 | 05:49 PM
thx i knew i needed thicker spacers in the back but is it alot more?
or the thing i can do is to measure the clearence between the fender and the wheel?
FirePhage
Tires and Wheels
Feb 20, 2014 01:29 PM
kiwiblazer
Tires and Wheels
Jun 26, 2009 11:25 PM
paxlineman
Tires and Wheels
Jun 10, 2009 08:57 PM
jimmy1996
Tires and Wheels
20
May 13, 2009 09:15 PM
Cavalier z24
Tires and Wheels
Mar 22, 2009 02:22 PM
