Is there a lift on my truck ?
Old Sep 30, 2017 | 12:32 PM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default Is there a lift on my truck ?
My mudding tires on my truck are going bald. I bought the truck with these wheels on it so I don't know if there is a lift on this truck or not but I'm pretty sure it does. Judging by the look of the picture, about how high is this lift ? The tire size on all 4 tires are 31x10.5 R15.
​​​​​​​Ok another thing, I want to eventually buy big swamp mud tires, what is the biggest size (H&W) that will fit my truck ? Without them rubbing the side panel when I turn.
Old Sep 30, 2017 | 12:41 PM
I found a guy selling some mud tires. Size is 32×11.5 R15, which is basically an inch bigger all around except the rim size. Think these will work without any problems with alignment or steering ?
Old Sep 30, 2017 | 04:57 PM
definitely has some sort of lift, but can't tell if it's body or suspension from that angle
can you take a photo from the front down low, maybe showing some of the front suspension?
Old Oct 5, 2017 | 12:47 PM
El_Beautor's Avatar
From the picture it looks like it might have a body lift to me. It looks like there is a gap in the rear fender well between the body and the frame. Look at the body-mounts and see if there are hard plastic spacers?
Old Oct 5, 2017 | 12:59 PM
I just found those yesterday, there on the front mounts too.
Old Oct 5, 2017 | 01:19 PM
That was my first thought too but I wasn't sure. Seems like there would be more frame showing under the center.
Old Oct 6, 2017 | 11:12 AM
There's also 2 spacers in the front...not sure of the size but I'll get back to u on that.
Attached Thumbnails Is there a lift on my truck ?-20171004_093419.jpg   Is there a lift on my truck ?-20171004_093402.jpg   Is there a lift on my truck ?-20171004_093505.jpg   Is there a lift on my truck ?-20171004_093445.jpg
Old Oct 6, 2017 | 07:45 PM
El_Beautor's Avatar
Definitely a body lift. The reason you can't see the frame very much is the nerf bars.
Old Oct 6, 2017 | 07:58 PM
chevyriders's Avatar
Looks to me like there is a body lift and small suspension lift. The tubular upper control arms look like something that would come with a 2.5" torsion bar lift to correct suspension geometry.
Old Oct 6, 2017 | 08:48 PM
OK with that been said, right now and in the pic, the tire size is 31x11.5xr15. What is the biggest size (H&W) tire I can put on without any problems?
