Tire calculation made ez
Firstly I apologize if you already know of this site but I have found it invaluablefor calculating tire clearance. Plus it tells you factory size calculations for a comparison with the new tire choice and ground clearance/speedo adjustment. Well worth a visit. :-)
www.net-comber.com/tirecalc.html
92 Blazer LTTahoe 4.3 (w)
No Java???
You could use the older one that isn't java - Miata.net - Tire Size Calculator - old
The colors annoy me... To each his own.
The only feature I like that miata doesn't have is the " Also, the ground clearance of the vehicle will change by x.xxx inches."
EDIT: I also like miata better because it gives you a visual representation of the old tire versus new, from the end and the side.
mohawks76
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 27, 2009 05:26 AM
