Tire + pothole = flat tire
Old Jan 29, 2011 | 09:11 AM
mov4x4's Avatar
mov4x4 is on a distinguished road
Question Tire + pothole = flat tire
So I had a flat tire lastnight(second flat this winter) and I'm guessing its from a pot hole. My question is how does it happen? Does the pot hole push the air out of the valve stem, (I had no cover on it) or does it put a small to large hole/cut in the tire?
Old Jan 29, 2011 | 09:37 AM
rriddle3's Avatar
Most pothole flats are the result of too little air in the tire allowing the impact to tear the rubber and break the belt inside the tire. It can also bend the rim and let the air out there. Did you locate the leak point?
s14sh3r's Avatar
It can break the bead loose from the rim if you hit hard enough.
Old Jan 29, 2011 | 04:25 PM
mov4x4's Avatar
I haven't really looked for where the leak is And it had 35 psi in the tire, also the rim doesn't look bent.
dbleobarbie
Jan 17, 2014 10:38 AM
ukneeldownb4me
Oct 31, 2011 05:27 PM
Blazertrish66
Apr 29, 2008 07:54 PM
m00nwater
26
Jan 12, 2006 10:31 PM
bufferpad
Feb 26, 2005 12:15 PM
