Tire pressure for MPG
Old Nov 17, 2006 | 03:31 AM
Kellen's Avatar
Kellen is an unknown quantity at this point
Default Tire pressure for MPG
I have a set of 30 inch muds(in my sig) they are a load C tire. Max PSI 45 lbs. When I got them mounted I asked the tire guy what he recommended and he put them at around 36lbs. I am wondering if anyone has insight into what would be the best pressure to have on long highway trips for maximum milage.
Old Nov 17, 2006 | 12:50 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: Tire pressure for MPG
hmm... I have 30 inch BFG AT's and they are rated at 50psi... the tire place only aired them to 35 causing them to squat... I upped them to about 43.... im afraid to go to 50 sounds awful high...... im interested to see everyones response to this...
Old Nov 17, 2006 | 11:07 PM
Hanr3's Avatar
I also have the BFG KO's in 30". I run mine at 42psi.
to find the exact psi. cover your tire with chalk, drive one full revolution and see how much of the chalk is left on the tire. If the center has chalk then your tires are underinflated. If the outside still has chalk then your tires are over inflated. Dont be surprised if the front and backs are different.
More air in the tire will make it stiff, and ride harsher.
Less air will make it spongy, and a smooth ride.
To much air and you wear out the center tread, too little and you wear out the outside edges first.
35 is what the recommended psi is for the stock tires on a stock truck. Its a starting place, all door stickers have the recommended psi.
Old Nov 19, 2006 | 10:50 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
I still have the stock tires and I run 32psi
PubEnemy
Aug 1, 2011 08:27 AM
kickme005
Tires and Wheels
Sep 14, 2010 12:04 AM
Spartan66
Jul 11, 2008 02:34 PM
nofear17bmx
Jan 21, 2007 06:02 PM
geekdagr8
Tires and Wheels
Sep 9, 2006 11:03 PM
