Tire size for 20" wheels and 2" body lift
Old 12-06-2013 | 11:11 PM
hypedave's Avatar
hypedave is on a distinguished road
Default Tire size for 20" wheels and 2" body lift
What tire size will I need for a 2" body lift and 20" wheels? Can 30's fit or am I out of luck with getting that offroad look with 20" wheels?
Old 12-06-2013 | 11:19 PM
00blazerS10's Avatar
00blazerS10 is on a distinguished road
I think your out if luck. i dont know if they make a 30 that will fit on a 20" wheel. but if you do find it let me know. I would love to see them
Old 12-07-2013 | 08:50 AM
El_Beautor's Avatar
You could probably run a 245/50/20 or maybe even a 255/50/20. The 255/50/20 is around 30" tall. Personally I'd suggest the 245/50/20 unless you're doing more than the 2" body lift just because the slightly narrower tire will help prevent you from rubbing on the fenders and frame.
That being said, I'm running a 265/70/17 (approx 32" tall) with a 2" body lift and 1.5" suspension and trimmed fenders. Anything is possible; it just depends on how badly you want to do it.
Old 12-10-2013 | 04:19 PM
hypedave's Avatar
Ok so let's bump this up to 22's.
With a 2" body lift, what size tires can I run?
With a 2" body lift and a w" suspension lift (4" total) what size tires can I run?
Old 12-11-2013 | 10:05 AM
El_Beautor's Avatar
Start here: Tire size calculator. Play around with tire sizes until you find a setup that fits what you want. There's writeups in the tech section to help you figure out what lift you need to fit a given tire height. Search is your friend.
goldnugget
Tires and Wheels
06-22-2014 08:20 AM
AGodlyCanuck
Lifting Tech
04-23-2014 09:56 PM
MWP
Lifting Tech
01-18-2014 07:07 PM
djcalma
07-05-2010 08:52 AM
whitejimmy
Lifting Tech
22
03-08-2010 02:50 PM
Quick Reply: Tire size for 20" wheels and 2" body lift
