What size tires?
Okay, I got a 1998 gmc jimmy with a s-10 front end conversion. and I was wondering whats the largest all-terrain tires I can put on stock s-10 rims that will fit..I can deal with a little rubbing.. I dont have a lift or a BL or anything. I was just wondering. Help would be appreciated. Thank you very much.
- Tmjdabomb
- Tmjdabomb
"Take a peak through this board. Just about every second thread is one dealing with what tires will fit on stock height. Remember too that the search feature is your friend
The simple answer is 30x9.50R15's are the largest you can fit on STOCK height. With a tbar crank and shackle lift (60-100$) you can fit yourself some nice 31x10.5's under there though. "
this is a quote from Sisk
https://blazerforum.com/forum/tires-wheels-13/everything-you-wanted-know-about-tires-6908/
. The simple answer is 30x9.50R15's are the largest you can fit on STOCK height. With a tbar crank and shackle lift (60-100$) you can fit yourself some nice 31x10.5's under there though. "
Boy...if I had a dollar. lol. This topic comes up around 2-3 times per day on the forum. lol.
Anyway, I should add into that quote from my earlier post that even with a shackle and tbar lift you may have some rubbing issues with 31x10.5 at full lock.
Blazonaire
Tires and Wheels
Oct 14, 2015 11:32 AM
Striker911
Mar 6, 2014 11:56 AM
98Ltblazer
Aug 19, 2010 07:06 PM
