What year do you think these came from?
Old Aug 15, 2011 | 06:55 AM
TheRandom1's Avatar
They might be from a 2WD vehicle so they'd stick out more, I think.
Old Aug 15, 2011 | 11:10 PM
mdehoogh's Avatar
Yeah they don't look like 4x4 backspacing. As long as they're not like 10" wide (they dont appear to be) then your tires shouldn't have a problem fitting on the wheels.
I might be a little hesitant since I think you already have 30x9.5(?) and lower offset wheels like that would push them out. Rear tires will be fine but you may run into rubbing issues with the front at the bottom edges of the fender.
If you have access to someone who can mount/unmount tires for you, I'd say it's worth $50 to try it out. If you have to pay to get them mounted, run into problems and then have to remount your stock wheels, you could easily spend more than the cost of the wheels.
Old Aug 15, 2011 | 11:31 PM
Benedict1337's Avatar
they look like american racing wheels, these to be exact
http://www.summitracing.com/parts/ARE-625861/
there are also the same ones with 6" backspacing
Edit: woops double post... and now judging by the lip those are probably the 3.75" backspacing ones the 6" ones don't have a big lip like the ones you posted
Old Aug 16, 2011 | 11:08 PM
DKSDAD's Avatar
Are there any little screws going around the rim on the section between the spoke section and wheel flang section? If so they could be Rock Crawler series 88's or Cragar 320's. Its hard to tell from the picture quality.
Old Aug 17, 2011 | 07:01 AM
TheRandom1's Avatar
I believe you're right DKsDAD, they're the Rock Crawler 88's.
chris015
Dec 25, 2012 06:41 PM
Bosgarage57
Tires and Wheels
25
Dec 22, 2010 02:00 PM
basketballmail2
Dec 16, 2007 07:43 PM
JST4SHO
Tires and Wheels
Apr 13, 2007 10:26 AM
mikeywaynebygod
Tires and Wheels
Nov 24, 2006 05:22 AM
