wheel info help
Old Mar 8, 2013 | 04:25 PM
arroyo-blazed98's Avatar
arroyo-blazed98 is on a distinguished road
Default wheel info help
looking for the info on backspacing for a 98 4x4 aluminum wheels,
will a 15x8 with same backspacing give me an extra outside inch without rubbing on stock suspension, and a 255/70 tire?
info and pics please......... not into black wheels....
Old Mar 8, 2013 | 05:28 PM
El_Beautor's Avatar
IF you can find a 15x8 with 6" backspacing (factory spec for 4x4 S-series trucks) it should fit with a 255/70/15 tire. I ran 255/70/15's on my stock rims and the only place I rubbed was on my sway bar, and that's because the end links were worn out and the sway bar was not centered. Once I fixed that the tires didn't rub at all.
The problem is finding a 15x8 aftermarked rim with 6" backspacing. Most manufacturers make them with between 4-5" backspacing or even less.
Old Mar 8, 2013 | 05:30 PM
so what would stock wheels be?
Old Mar 8, 2013 | 06:57 PM
Jamaroon's Avatar
stock is 15x7 with 6" BS
Old Mar 9, 2013 | 10:50 PM
so would a 15x7 with 4.5 backspace work?
on stock height with 255/70s
not sure if i got this backspace/offset stuff figured out.....
what would rub if any,` or will it be 1.5 more outside stock wheels?
Old Mar 9, 2013 | 10:51 PM
if u could show a few pics, i could tell u the look i want.........
please help
Old Mar 10, 2013 | 02:28 PM
Jamaroon's Avatar
4.5" BS would stick out 1.5" further than stock on each side. They might rub on the fenders while turning.
rdhoping72
Oct 6, 2010 07:42 PM
bluebeast
Apr 7, 2009 09:25 PM
Bad4x4NoMa
Lifting Tech
Apr 26, 2008 07:08 PM
2klt
Apr 28, 2006 09:36 AM
2klt
Apr 2, 2006 11:37 PM
